BFL13
Aug 04, 2013Explorer II
What about the battery fuse's fuse holder? Any corrosion there?
On the DC fuse panel inside, are all wires tight, especially the big battery wire lug set- screws?
Turning on the lights and getting a beep suggests that turning on the lights draws so much battery it makes the voltage low enough to set off the LP alarms low-voltage alarm. It should show red? light as well as beep while it still has any juice left to run those.
That would indicate a major loose connection? --back to that fuse holder? No idea.
Another elimination test is to disconnect the battery with shore power on so the converter only is doing the 12v. This by-passes the whole battery fuse area.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
