wa8yxm
Jun 19, 2017Explorer III
First there is no such thing as a 110 to 30 adapter. 30 amps is 110-120 volts.
What you were using was, depending on your point of view a 30-15 amp adapter or a 15-30. BOth ends are the same voltage 120.
Now, the outlet you plugged into.. Was that for a Dryer, or some power tool originally>
If so it was likely a 240 volt outlet and you fried everything.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
