dougrainer
Aug 04, 2015Nomad
On Jayco products that used that system, the controller was inside the entry door. You removed the window in the door and the controller was located in the cavity below the window. IF you do NOT have the spring loaded pins in the door frame on the hinge side, the controller will be inside the door. IF you have those 2 spring loaded pins in the door frame on the hinge side, then the controller will be inside the RV somewhere. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
