TenOC's avatar
TenOC
Nomad
Feb 28, 2023
2014 3100RL Living room slides would not move
I have a 2014 3100RL Montana 5th wheel. I was getting ready for spring check out and the living room slides would not move. No movement whatsoever maybe like a fuse is blown someplace. The bedroom slide works okay. The 2 fuses located near the hydraulic pumps as well as the 2 reset-able ones at the bottom are good. Any suggestions on where to check next.
Click For Full-Size Image.
In the photo above does the Red or Black lines control the slid????
1 Reply
  • Check the solenoid valve. You have a hydraulic system, the solenoids control which slide moves. The hydraulic system does not move all 3 at the same time, mine doesn't. It will move the smallest/lightest first and the heaviest last. Run the 2 out that do move and run them to their limit and see if the last one moves then. If it doesn't, you have a solenoid valve not opening.
