dougrainer
Dec 02, 2018Nomad
IF you have a Firefly/Spyder Networked touch pad control system, remember, they do NOT get rid of any fuses needed. If a appliance requires a fuse, there will be a fuse. Obviously, any 12 volt appliance will have a fuse protection. FINDING it can be a challenge. Most Firefly/Spyder systems have 12 volt Circuit Breakers on a main panel somewhere in the RV. Usually 2 such panels, depending on the size of the RV. The LED Awning lights are probably fused at the same area of the regular inside lighting system fuse panel. Doug
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
