D_E_Bishop
Feb 09, 2015Explorer
bigfootford wrote:D.E.Bishop wrote:
Some really detailed explanations here, all will work, but the simple answer is look at the label (required by UL) on the back and you'll find your answer.
I know UL does not write laws and bla, bla, bla.
"K.I.S.S."
Now that is not a good answer!
Some folks do not understand the conversion of watts to amps or amps to watts. Couple that with an inverter and it's inefficiency factor along with the conversion to DC....
How do you K.I.S.S. that?
Jim
If inverters are rate in WATTS and the TV is rated in WATTS, that is simple. And, therefore, a fairly good answer.
