DiskDoctr
Jun 06, 2017Explorer
BFL13 wrote:time2roll wrote:
I went 2/0 for the parallel connectors. Undiscovered bad connection could put full amps through one side.
Forget a switch and just have a fuse on the positive main cable near the battery. Fewer connections the better.
That is a valid point. Using twin thinner wires instead of one fat wire has that risk. Now it is down to your fuse(s) EG with a spec for a 300a fuse on the fat wire, you could go with two thinner wires to the 300a fuse or have a 150a fuse on each wire to the pos battery post.
In the latter case the 150a fuse on the one thinner wire now taking 300a would save the day.
All wisdom from you guys there :)
So should I use the threaded posts or the terminals? Any preferences?
