DiskDoctr
Jun 07, 2017Explorer
MrWizard wrote:
If you run over 200 amps for several minutes
That might be a problem
A start up spike on the MW would only last seconds at the most and still be under the 200 amps
There is no single item in the RV that can consume that much power
You would need to run wh and MW at the same time
And you don't have enough battery to run the wh from the inverter
And take showers
What do you expect to do that is going to require extended power over 200 amps
I have a 200 amp shunt
And I have baked potatoes in the mw 5~8 minutes, depending on the potatoes
No problems
I like potatoes ;)
400a, I was looking to build the wire for the max input/output of the inverter. WH would be on only propane at the time and no A/C or electric griddle ;)
There *may* be solar in our future, but not yet. (Just added that to make everybody cringe, LOL)
Please check this battery bank wiring, I flipped the second set to make wiring simpler...maybe.
