Optimistic_Para
Aug 28, 2018Explorer
An EMS also monitors the voltage level and will shut off if it either goes too high or too low.
In a packed campground, if everybody's air conditioners are running full blast, it's not unusual to see the voltage drop to below 105 volts. This can damage equipment, as can voltages above 128 volts, which is not high enough for a surge guard to notice and deal with.
High voltages are much rarer than low voltages, but can happen under some circumstances. I once measured 142 volts on an outlet powering some equipment I was trying to troubleshoot on my job, before I retired.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
