DrewE
Aug 29, 2018Explorer III
Optimistic Paranoid wrote:
Neither your Surgeguard, nor any of the testers you are using, will protect you from the kind of dangerous mis-wiring that will electrify the metal parts of your RV, called a 'hot skin condition'.
Go to YouTube, search on 'hot skin condition' and you will find several good videos explaining how this happens and how you can test for this potentially deadly - as in 'can kill you' - situation.
The SurgeGuard would generally protect from danger in a hot skin since it has a GFCI built into it. Any leakage from the hot skin to ground would trip it--and it ought to trip immediately if the ground lead were continuous through to the surge guard unit, even absent any leakage current. The others which lack a GFCI would not detect this condition.
Certainly a hot skin condition is very dangerous and should not be ignored (and is well worth checking for). To be honest, I don't entirely understand why RV receptacles aren't required by the NEC to have GFCI protection.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
