time2roll
Apr 27, 2018Nomad
Yes you can get an adapter but will be pulling from just half the generator. So it becomes 4000 watts and is plenty for a 30 amp RV. Not sure how the mining equipment fits into this. Probably two of the 5-15 outlets come off each side so if you need 120v you are in good shape. A 240v dewatering pump may require the RV to be unplugged or go to low power outlet.
3500w Champion with RV plug
L14-30 to RV30-TT adapter:
https://www.walmart.com/ip/AC-Connectors-RVL1430TT-Generator-4Prong-L14-30P-30Amp-Locking-Plug-to-RV-TT-30-RV-30Amp-Female-Connector
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Aug 08, 2019
