wa8yxm
Apr 28, 2018Explorer III
The Generator is a 30 amp "TWIST LOCK" and may be 3 or 4 wire the 4 wire versio is a 120/240 volt plug.
The plug for the park is a TT-30 120 volt ONLY
The pair at the RV is a Marinco
You will need only two adapters
A 30-50 RV adapter for sites where the 30 amp outlet is ... not good but there is a very good 50
And a Twist Lock to TT-30
Why The Twist lock on the genny? If you had just a TT-30 there odds are on many generators engine and generator vibration it would quickly fall out. but the TWIST LOCK hangs in there.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Aug 08, 2019
