time2roll
Oct 10, 2013Nomad
#6 from the panel is fine. #8 is fine. You only need #4 to get full surge performance that you will never ever need. Probably you will never max out the inverter and more commonly use 75w to 250w and no surge.
Since you are right there at the distribution panel connect a small transfer switch in the one circuit you need. I recommend Xantrex Prowatt for about $50.
This is how mine is wired... except I went two transfer switches and ALL outlets share the 300w.
No wire to pull, just make the connections. Done.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
