tenbear
Oct 10, 2013Explorer
If you are going to run it off the fuse panel I would check the wire from the battery to the panel. Mine had about 20' of #8 wire. That plus the wire you add may result in too much voltage drop. I replaced the battery to panel/converter with #4 wire when I replaced the old converter with a modern 4 stage converter.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
