SFVdave's avatar
SFVdave
300w solar panel system
Any difference in buying 3x100 watt rectangle panels(47"x21") vs 2x150 watt square(39"x39") panels? Would square 150 watt panels need 4, 6, 8 mounts. 3 panels placement may have less chance of shadow than 2 panels. 100 watt panels have much less width than 150 watt square and less exposed surface area where driving wind hit panels, does that make a difference?
  • Almot's avatar
    Almot
    Explorer III
    SFVdave wrote:
    Since it's square, 2 mounts on each side, 2 mounts on each side a one on front and back or 2on all four sides? They are 39x39".
    Depends on how many screws per mount, and how big mounts.
    I mounted much bigger panels 65"x39" on 4 big L-brackets each panel. Brackets are 4x4 angles 6" long, 1/4" thick. So each bracket has 4"x6" footprint. In each 4x6" footprint I used on the average 5 tapping screws #10, some going into the rafters and some just in plywood. With plenty of Dicor under the bracket.
    L-brackets are attached to panels with machine screws into the rivet nuts in the sides of panels. I didn't use OEM mounting holes in the panels, those require Z-brackets. The plan was to tilt panels to either side, Z-brackets into the bottom of the frame would make it difficult. "Tilted plan" was later abandoned since 500W flat array proved to be enough for me.
    You can probably get away with 4 brackets per panel, 3 tapping screws per bracket. Make brackets long, about 6", to space tapping screws further from each other. Machine screws holding brackets to panels - 2 screws per bracket is enough.
  • Westend, you are right 16.75 for 2 150w and 17.25 for 3 100w. That's .5 amp difference.
    Thanks
  • grizzzman wrote:
    westend wrote:
    Wind doesn't make any difference unless you plan to install the modules incorrectly.
    I believe the difference you might see is that 3 x 100W panels harvest more amperage than 2 x 150W.
    Why do you believe (harvest more amperage )?
    Thanks
    Generally, what I see with ratings is that by increasing cell count on a module, the gain in amperage is not linear. If you have two 150W modules they may be rated at (8.3 amps/module X 2 = 16.6 A, theoretically). The 100W modules may be rated at (5.8 amps/module X 3 = 17.4 A, theoretically).)
    Thanks
  • Will go with larger panels. Since it's square, 2 mounts on each side, 2 mounts on each side a one on front and back or 2on all four sides? They are 39x39".
  • Wind doesn't make any difference unless you plan to install the modules incorrectly.
  • I'd always go with the largest panels that will fit the available unshaded space. Every extra connection is a possible failure point.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
