kohldad's avatar
kohldad
Explorer III
Nov 05, 2014
30A/20A pedestal
For some reason I'm drawing a blank though I could wire a complete house and have done so in the past.
Installing a 30A/20A pedestal with breakers at my daughter's house. I want to have full use of both outlets at the same time so when we have two campers they each have a plug. Purchased a pre-wired 30A/20A box which will only be about 15 feet from the meter combination box. I have room for two breakers in the box.
Thinking I should just install a double 30A breaker in the combination box, run 10-3 in buried conduit to he pedestal.
Problem I'm having is since I will be using each outlet separate, will the 10 ga neutral be sufficient or should the feed actually be #6 to have the neutral large enough to handle the return for 30a and 20a outlet combined?
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 06, 2025
