rockhillmanor wrote:
gcloss wrote:
Sounds normal and the circuit breaker did it's job.
Yup X2!
When you have the ac on in an RV.....micro's, appliances, etc can not be plugged in at the same time. Even with the AC off, you can not plug in 2 appliances that draw a lot of amps. You only have 30 anything over that in combinations trips the breaker.
It's the nature of the beast, get used to it! :C
They can be plugged in, you just can't use them all at once.
It's been my experience that on 30A you can run two major items at once.
