JKwock wrote:
Yesterday, I had the ac, electric water heater, and rice cooker going and it kept triggering the 30amp breaker outside. I went to the gas water heater and everything was ok.
today, at a different campground, I had the ac and electric water heater and it triggered the 30amp breaker again so I went back to the gas water heater and so far so good.
Is the electric water heater and 15,000 btu AC too much for 30 amps???
AC 12-15 Amps
WH 15A typically
Rice cooker 10-13 amps.
Fridge on AC 3-5 Amps
add in the converter and a few other things and you can see that all three running are way over the 30A breaker limit. Two are pushing it if anything else is on.
Even AC and microwave are pushing the limit if on together.
