wa8yxm
May 25, 2015Explorer III
FIRST: You said you need to plug a 30 amp cord into a 110 outlet...
30 amps is 110-120 volt.. Same as the 15/20 amp outlet on your house..
Second: Sears and K-mart sell a 12ga Extension cord, up to 100 feet long (I have one) with a push button on the outlet end that you have to push in order to plug in that puck or dogbone adapter others have mentioned or your dealer sold you.
If you are going to run that far.. USE a 12 ga (or heavier) cord.
In fact you might consider a 30' 30 amp extension (never know when it will be needed) and go with 50' of 12ga (Again th push button ones from Sears/K-mart)
