DrewE
Aug 31, 2021Explorer III
For the usual paralleling systems/setups, only one is needed. The parallel kit simply wires the higher-capacity output receptacle to both generators: the hots all tied together, the neutrals all tied together, and the grounds all tied together. The actual "magic" that makes paralleling work is built into the generators themselves. Anyhow, since the neutrals and grounds are tied together across both generators, putting the bonding plug in one generator bonds the whole system.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
