mrunella's avatar
mrunella
30amp Gen/50 Amp RV Generator Help
Alright folks, need your help as I am at a lost on this one. We have a 2022 Thor ACE 32.3 Motorhome that uses “50 amp” service. I have a Firman Generator that has the TT-30R receptable on the side (30amp/3650 watts/120). We would like to be able to run our RV off this generator (obviously I know I won’t be able to run both AC’s and the microwave at the same time). Coach keeps coming across with “SHORE POWER DEFAULT” code. I know that a lot of people are able to run their 50amp RV’s off 30amp service, just have to be very careful to not overload it (i.e., AC units, microwave, etc.). Thoughts?
I have tried…
Generator (30amp) with 30amp to 50amp dog bone connector to 50 amp cord to COACH: NO GO
Generator with 30 amp cord directly to coach meeting a 30 AMP to 50 amp connector into the coach: NO GO
This worked perfect on our other coach, any thoughts?
  • This appears to be a newbie hit and run post. I was really curious why the OP wanted to do this with an onboard genny. Guess we'll never know.
    3 reasons I can think of:
    1. Quiet - not only is is a small inverter generator quieter than the onboard generator, you can move it farther away from your unit.
    2. Fuel efficiency, at low loads, his Firman 3650W will use about half the fuel per hour of an onboard QC4000. I used to wish that RV makers would include high quality inverter generators for better fuel economy and quietness, but now they are moving to Solar with Lithium batteries which can actually power the A/C for a while, which is even better.
    3. CO safety - you have less chance of exhaust blowback when your generator is 20 or 30 feet from your RV.
    But the most likely reason in this case - generators are often an extra-cost option, on the A.C.E. it's bundled with the dual A/C option so it's even more expensive than just a generator (and generators may be in short supply along with everything else, so maybe it would affect his delivery date).
    I don't know what Thor charges for it, but list price on Onan 4000 is around $3500... list price on his Firman is $750. Of course, the onboard is much more convenient since you don't have to fuel it or walk outside to turn it on (though you can get portables with remote start).
    On an older RV, it's also possible that the onboard generator stopped working and fixing it would cost more than the price of a portable generator.
  • I don't think I have ever seen a MH in recent years that did not have a generator despite manufacturers calling them "options". Likely the dual air was the option with a QC5500 over the one air with the 4000. In either case I would bet dollars to donuts that it came with a genny. Maybe he had a problem with it, we'll never know.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
