Carb_Cleaner
Aug 10, 2014Explorer
Sweet. Thanks for all the replies. I knew it was something like set the bearings at X amount of torque, back off, hand tight, stand on your head if it's a full Moon on a Tuesday then back off a little. Putting the first brake assembly, new bearings packed with Mobile 1 grease (on Dexter's list of approved greases), onto the axle in about a minute.
This is what I've found on Dexter's site:
50 Ft/lbs while rotating the hub, back off, then finger tight. Back off to engage the cotter pin or, in my case, not a cotter pin but a "retainer" (it slips over the nut with a machined flat spot that the axle holds). It's not "pre-load", as mentioned above. It's actually "end play". Just a touch.
Directions here, page 56:
http://www.dexteraxle.com/i/u/6149609/f/600-8K_Service_Manual/Hubs_Drums_and_Bearings.pdf
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
