Ron3rd
Aug 10, 2014Explorer III
Lynnmor wrote:Ron3rd wrote:Ranger Smith wrote:
From what I remember when doing mine it was torque axle nuts to 50 ft. lbs and then back nut off to next cotter pin slot.It is a little more involved than "hand snug" as everyones idea of hand snug is different
That is correct, and I don't remember the exact torque required but it's in the Dexter instructions available for download. Basically, you torque the bearing to the spec and rotate the wheel to seat the bearing and then back off to the first cotter pin hole. My old trailer had Dexter 3500 lb axles and I did this several times, easy process.
BTW, most techs I've watched don't use a torque wrench; they tighten the nut down with a large Crescent wrench or Channel Locks, rotate the wheel and then back off the nut. Probably close enough but I prefer to go by the book as it's no harder.
Wrong again, this will result in a pre-load condition.
Wrong? Then Dexter's instructions are wrong. Take it up with the factory! The bearings are supposed to be preloaded btw.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
