Carb_Cleaner
Aug 11, 2014Explorer
westend wrote:
...Thanks but you're cheating with that piece of plywood under your parts. ...
A piece of plywood AND a proper sittin' stool. I've come a long way from cardboard and a cinder block. LOL. I'm still working on gravel, though.
Lynnmor wrote:
Dexter
Bearing Adjustment and Hub Replacement
If the hub has been removed or bearing adjustment is required,
the following adjustment procedure must be followed:
1.
After placing the hub, bearings, washers, and spindle nut
back on the axle spindle in reverse order as detailed in the
previous section on hub removal, rotate the hub assembly
slowly while tightening the spindle nut to approximately
50
Ft.
Lbs.
(12" wrench or pliers with full hand force.)
2.
Then loosen the spindle nut to remove the torque. Do not
rotate the hub.
3.
Finger tighten the spindle nut until just snug.
4.
Back the spindle nut out slightly until the first castellation
lines up with the cotter key hole and insert the cotter pin.
5.
Bend over the cotter pin legs to secure the nut.
6.
Nut should be free to move with only restraint being the
cotter pin
Since Spring of 2002, Dexter's EZ-Lube 3,500 pound axles come with a "nut retainer", without a cotter pin. I purchased my trailer new in January of 2003. It has the nut retainer system.
The 1 1/2" socket I have is 3/4" drive. I didn't have an adapter for my 1/2" torque wrench so I used a 3/4" breaker bar, choking up on the handle to mimic a 12" wrench and hand tight, per Dexter's instructions (back nut off, finger tight, back off , etc.). After using the hand method to pack the bearings and throwing a bunch of grease in the hub as I went, I used the EZ-Lube zerk to fill it with grease. The hub was rotated constantly as I pumped the grease and I tried not to use a lot of pressure. I hear the grease seal can blow out the back of the hub. It took a bit of pumping, but grease made its way through the hub, oozing out the front. I need to wrap up the electric (preliminary tests were good) and get a brake spoon to adjust the shoes. Then, I can run it around the block. If I didn't pump the drum full of grease, they should work.
I'll be using a factory Ford brake controller via the factory 7-way plug. I'm adding a fused, constant 12V hot to the trailer, too. Back-up lights will have to wait.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
