- jasultExplorerTom_M you are correct. I had problems with the ties snapping
- TomG2Explorer
eocamper wrote:
It's the basic Champion 3500/4000 with a 30amp outlet. Again. I am looking at emergency purpose. I live in So. TX and would like a back up if a hurricane hits and we lose power for a few days.
Basically, if it will run on 30 amp park current, it will run with the Champion. - Tom_M1Explorer
jasult wrote:
I noticed what appears to be hose storage is tie-wrapped to the bumper with white ties which are not UV resistant. These will deteriorate in a fairly short time from exposure to the sun. It would be better to use black UV resistant ties.
that champion will do just fine with your ac.
Here is a pic of mine that follows me everywhere. I only use when no power available. - greenrvgreenExplorerI have the Champ 3500 and $280 is a GREAT price for a great genny.
I've run my 13.5 k A/C from my Champ 3500 in 103 degree heat at almost 4000 ft. In that heat and altitude it started and ran perfectly.
I have inverter gennies that I use now for camping and I keep my beloved Champ for home backup. IMO you cannot beat the Champion 3500 for quality in a synchronous genny. - jasultExplorercan't beet that
- eocamperExplorerThanks for the quick replies. I can get it where the Mrs. works for $280 after her employee discount.
- jasultExplorerthat champion will do just fine with your ac.
- eocamperExplorerIt's the basic Champion 3500/4000 with a 30amp outlet. Again. I am looking at emergency purpose. I live in So. TX and would like a back up if a hurricane hits and we lose power for a few days.
- apr67ExplorerMy older Generac 4000xl runs a AC fine hear at sea level.
- j-dExplorer IIWhat kind of Generator? I ask because "jobsite gennys" are often rated at 240-VAC. That's two 120-VAC legs at half the rated wattage. So a 3500-watt jobsite genny provides two 1750-watt circuits. A campsite genny, say 3000-watt Honda, lets you draw all 3000 from one circuit.
So find out how the generator is set up. Harbor Fright, who I don't necessarily recommend for generators, only as an example, had two jobsite type gennys. One of them featured a 30A outlet. That setup would start and run a rooftop A/C.
Most jobsite-style gennys are noisy.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
