Gdetrailer
Jan 16, 2022Explorer III
StirCrazy wrote:Gdetrailer wrote:
Company I used to work at used 3d printing for proof of concept and engineering mockups for some of their new products..
Works great for that.
However, strength and desired finish can be less than stellar at times since the plastic is applied in layers rather than all at once.
Because of that, they had actual traditional injection molds made for actual production runs for parts that strength and looks were critical.
But, hey, you have it, you like it, may as well use it.
it depends on the type of filiment you use and the orentation you print it in, you can build it strong. injection molding it more for the high capasity and speed. 3d printers are not known for knocing out the parts and in that world time is money.
I have only don't a couple prints on mine so far. its working great, but I am waiting for a few upgrades to come in then I have to dial it in all over..
Speed, type of filament, thickness of each layer all play a part in the final outcome in finish and strength.
For one of the prototype printouts I have worked with, they may have used larger, thicker slices because the main part was pretty large at a little over 2ft x 2ft and 8" tall for the main body.
We were tasked with the job of stuffing the box with a micro ATX system board, several power supplies, a scale, a touch screen monitor some imaging cameras with lots and lots of wiring. Screw holes that were supposed to mount many of the items inside the box easily stripped out, often would not hold things in place.
Had to be careful on how you handled the box as it was very easy to crack the box and the device would have to be torn apart and the box scrapped.
For the actual production runs, the engineers moved to a injection molded setup and had thread brass nuts embbeded in the plastic.. Much better strength and once we were no longer attempting to screw directly into the plastic the screw issue was gone..
Small items, strength and speed become a moot point.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
