LittleBill
Feb 10, 2022Explorer
StirCrazy wrote:LittleBill wrote:2112 wrote:LittleBill wrote:Ouch. What broke?
mine broke today, having withdrawal issues since parts won't be here till monday.
Mine is 6 years old without issue other than early on the X axis belt pulley slipping on the stepper shaft, causing X shift. The tiny set screws kept backing out. A dab of VC3 took care of that but I doubt I'll ever get them back out.
extruder tensioning arm, known issue on mine, also have replaced fans a couple times (going to ball bearing) and a z limit switch issue.
is what it is i guess. printer has about 500 hours on it.
the real amazement is not the printer, but once you can design, the world it opens up, is crazy.
I also design for money and have one product on amazon now, and soon to add more.
I ordered the BMG clone from diamondlabs in antisapation of that going on mine. so far I have put the dual Z screw kit in, added a bl touch, doing the extruder and when I can find a raspberry pi in stock I am going to add octiprint and change to liniear rails. I am also starting to source parts to build a voron 2.4 and add a second printer.
Steve
Mine is not modified much, spring, capricon, a modified extruder guide for TPU, and bl touch, and ubl with jyers.
It prints amazing. I have 0 reason to change anything at this point.
IDK if I want to go full custom like a voron, I tried octoprint, its nice, but surprisingly i print predominantly from the SD card.
if your going with a pi, look at klipper.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
