StirCrazy
Apr 04, 2022Moderator
LittleBill wrote:StirCrazy wrote:LittleBill wrote:
I am using petg here. that said I do have touch of warp in 3 corners, i turned the bed up a touch. hopefully it stays in place. its over half a roll of filament for it.
is that garolite?
Hairspray cured my warping on big prints.
what are you making a base for a light?
i despise glue and hairspray. I understand a lot of people use it, If it fails i will run a hotter bed. this is the first failed print, in the last 100, (also my largest)
if you look back the post with pictures, there is a link to what its for. its a base for an autoformer.
ya I won't use glue, I only started using hairspray as I maxed out my bed temp and was still getting a bit of end warp but I was making long skinny things. it did allow me to drop bthe bed temp down to 80 with PETG. I did just recive PEI beds so mayby I can ditch the hairspray now also.
Steve
