LittleBill
Apr 05, 2022Explorer
2112 wrote:
Dang weird looking support. What slicer do you use? I'm guessing Cura.
Nice job *thumbs up*
Could you have created a ledge with some weep channels to support the auto transformer and left the center open? I guess to ask it differently, is the grill necessary?
that is upside down tree supports. I will provide a better photo.
the autoformer weighs 21 pounds. i think the edges are only 6mm thick. that said that grid is a drain pad for water, and drains to a canal then exits via the holes on the side.
after placing the unit on the stand, 99% of the grid is covered, not sure if it was necessary, but it was a edge plane, which was a new technique to learn, so I am happy with that.
Honestly i just ripped off hughes design, after thinking about your comment. i guess opening up the bottom would have been doable, and reduced the time and material. there are about 6 changes I would do, but this worked better then expected.
I do use Cura. "Combing" almost destroyed that grid. first time I have ever seen a design do that. I either need to turn combing off or go to z hop for this part. thats why the top looks so rough. it easily made 400 + combing passes.
