64thunderbolt wrote:
if it runs while in storage means it is running constantly off & on on a 24 hr per day for how many years?
He answered that in the original post. Longest any of them has lasted is ONE year, Jan 14 to Jan 15, the first one did not last that long (April to Jan).
I too wonder about that "Fail to cool" I can think of a few reasons that can happen.
Condenser coils clogged with cottonwood seeds (That did it for me, a quick cleaning and all was good).
Compressor motor burned out: Common issue where voltage is low, Install a Progressive Industries HW-30C or HW-50C depending on trailer power plug (50 amps gets the 50C, 30 the 30).
Even if the voltage is good (IS where I am parked) Flickers can (And have here) happened, this is where the power goes off sometimes for less than one second, just long enough to stop the compressor, which then tries to restart with full head pressure.. NOT GOOD, the HW-#0C will hold power off 2-3 minutes so the compressor can bleed down and re-start normally.
Finally,, On my Carrier Air-Vs (this may be model specific) there ar ea couple of vibration traps, these are like the water traps in a drain, pipes go down and back up in a U shape.
They have these thigns rubbing up against each other.
And that is why I now have a 15,000 BTU air conditioner in my bedroom, pipes rubbed each other holy.
(The front one I spread the legs a bit so they do not chafe and I expect it to last a long time)
