The 8 hole was introduced in 1992 and later.
Do Not use braided extenders they will leak and if they fail it can lead to catastrophic tire loss.
What you want is solid extended Valve Stems,The best on the market,that are the original,are
Tire Man.
Chuck is the original designer of these an he has been around for years. If you have any questions just give him a call, he is always happy to help. Any others are just cheap reproductions of the original.
The kit looks like
This it is for all 6 wheels,they also come with flow-thru valve caps so you don't even need to take then off to check the pressure.
Here is a list  of all the products he sells.
They are compatible with all Tire monitor systems.
