Gdetrailer
Jan 08, 2021Explorer III
MEXICOWANDERER wrote:
I have a driveway gate opener. Takes her 10 seconds to swing both sides open. Small driveway. When car is nosed to wall there is a meter clearance to the closed gate. Mexican screen door on the house. Probably weighs 100 pounds. Not screen it is perforated sheet metal. Sucker would probably stop an anaconda.
It's not the lighting in the dining room as it is my weak eyesight. I can look straight into these "100 watt" eqvt bulbs from 3' away without dazzle. The kitchen has a 35 watt corn light. The walls are white and I may be the victim of Chinese BS as far as power ratings and wattage is concerned. Here in bed' away the 100 watt eqvt standard LED bulb forces me to light up the screen on my kindle.
Mex, pretty much any of the 4ft "shoplights" will be much brighter than a "100W equiv" light.
As you can see from my Lux readings two 18W 4ft LED replacement bulbs are more than twice the brightness of two 4ft 40W T12 fluorescent bulbs. I would highly recommend never looking directly at the LED fixtures, they are like having the "sun" directly in your eyes.
If you compared T8 fluorescents it wouldn't be as much of a difference since T8s are more energy efficient and brighter than T12 bulbs but still the LED replacements would still be brighter than T8s.
Comes down to how you feel about buying non relampable fixtures that WHEN the LEDs in them start dying you WILL have to replace the entire fixture instead of a single "tube"..
If you don't have fixtures then buying non relampable would be cheaper now at $20 per fixture, but down the road, you will have to spend another $20 for a complete new fixture.
Where in my case, I will spend $10 for one "tube" although I spent $15 for each fluorescent fixture and $10 per tube so I have $45 in each fixture. But down the road, I will not have to remove and replace the entire fixture and repairing will cost $10 for the tube that quit.
I don't really trust those highly discounted cheap non relampable shop lights to have a long life after dealing with bunches of inferior LED lights that flooded the market. Which is why I settled on reusing existing fixtures by retrofitting.. And where I wanted more light, I bought T8 fluorescent fixtures and retrofitted those to LED. Not to mention relamping existing fixtures makes my future relamping fast and cost effective.
But, hey, not everyone is willing to step up to the plate with better color selection and lower future replacements but they are willing to sacrifice quality and life for the cheap price upfront, I get it..
Mex, I know you are a perfectionist and a tinkerer so I am not sure you will be satisfied with a non relampable fixture but that is your call.. You might be able to tear them apart and relamp with your own choices down the road but seems like it would make life easier down the road to have a "plug and play" easily replaceable lamp..
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
