dougrainer
Jul 15, 2016Nomad
The 7 way and the connected 4 way are fused seperately from the Chassis system. That means the Tow plug will have seperate fuses. They started this almost 20 years ago to prevent a short in the Tow wiring from disabling the RV or Truck lighting. You do not state if Ford/Roadmaster/Freightliner or Workhorse. Endeavor should be a Roadmaster chassis. But they all have separate fuses for the Tow plug. Those fuses will be in a standard fuse block with other chassis fuses. Doug
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
