dougrainer
Jul 16, 2016Nomad
47LS3 wrote:
Thanks again. I have been trying to find the power source(fuse)?For this Roadmaster chassis, Endeavor. None of the fuses,that I have found, are labeled as trailer or tow etc. I suppose I could pull every fuse one at a time looking for a bad one..
I have attempted tracing the yellow and green wires. All wiring is inside the convoluted plastic conduit. There are about 50 bundled together running thru the engine compartment and I gave up.
Chuck
They are rarely labeled. I ALWAYS have the Ignition key ON and then check EVERY fuse at all the chassis fuse block assbly's. I use a 12 volt troublelight and it takes no more than 10 minutes to check all the fuses. This way you find every fuse that is blown even the fuses you did not know were bad. Doug
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
