RedRollingRoadb
Oct 27, 2013Explorer
Had a similar problem, one day everything fine, next day nothing. In frustration I opened up the generator circuit breaker cover and found that the hot input wire to the breaker used a spade connector and it had vibrated loose. Cleaned it up and pinched it a slight bit and had power once again. Good luck.
