Handbasket
Oct 28, 2013Explorer
Bobbo wrote:CloudDriver wrote:
Did you check the circuit breaker on the generator? It's to the right of the start/stop switch and toward the back. Did you check for voltage at the AC outlet for the generator (where you plug in the shore line to get power from the gen)?
+1
This is the primary culprit in this circumstance.
+2. If a Micro-series generator (assumption, that) actually isn't generating voltage, it loses spark when the start switch is released. The engine stops.
Jim, "My mind works like lightning. One flash, and it's gone."
