Just got home from a trip a couple of weeks ago and slide worked fine on the trip...No sounds or anything else indicating a problem...When we got home we put slide out to empty MH and then put it back...
If it really is the 3rd motor to go bad, wouldn't we have to think the motor is being overloaded ? I think you need a better technician that would check the amperage draw against the ID plate. And if it is over amping, it needs a bigger HP motor. In the meantime, I would hot wire 12 volts directly to the motor, see what happens
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
