rhagfo
Jan 01, 2017Explorer III
mikestock wrote:
This dwelling has, what appears to be, two parallel 200 amp boxes. It is about 4500 sq. ft.
The wiring, somehow, passed inspection when my son bought the house, last year. As someone said, this modification was done with, what appears to be, a piece of a 30 amp RV extension cord.
I have a 50 foot RV extension, purchased for use here only. For now, I will change this over to a 30 amp setup, using the existing cable until I can get it repaired to use the 50 amp setup. Summers, here often require two air conditioners and there is no shade,
I would not use at all and would totally remove, sounds as a total improper and illegal connection.
Then do a correct and legal install.
