ktmrfs
Jan 03, 2017Explorer III
Harvey51 wrote:
I wired my garage according to the unofficial wiring code book. The sub box ground is a heavy plate buried in the ground (the rod couldn't be pounded deep enough). The only explanation I could find for not connecting ground to ground or neutral wires from the house was that someone might accidentally dig up the cable to the house and cut just the ground and neutral. Is there a more likely scenario that would cause a problem in the garage or RV?
"Bonding" is another word for connecting, right?
you can connect the ground to the ground in the main distribution panel, that's the typical way to do the ground per NEC code.
connecting ground to neutral downstream of the main distribution panel is AFAIK against NEC code. that is why trailer grounds and neutral are isolated, as is every appliance or other thing you connect downstream of the panel.
Ground is there as a GROUND and is to be protected as such and never have any possibility to be otherwise.
