Pipeman
Mar 29, 2019Explorer
50 amp cords
When I connect my 50 amp cord to my 50 amp extension cord, I have a heck of a time getting them apart. Anyone know of a way to make that easier?
Pipeman wrote:That only puts you 3 years older than me. LOL I was going to recommend the screwdriver usage too, but it's scary thinking about what can happen if you unthinkingly use the screwdriver before unplugging from power. I've used a screwdriver when my plugs semi-welded themselves together when my EMS gave up the ghost and shorted out. But the idea made me very nervous even though I knew it was unplugged at both ends.fj12ryder wrote:
Maybe some dilectric grease on the prongs, but you really want the connection tight. If it's loose you run the risk of arcing and resistance heat buildup and possible plug failure, i.e. melting.
So time to hit the gym and build up those pecs. :)
fj12ryder, I'm an old guy, more mature(73) but not weak. I have old mans' skin and it isn't pretty when wearìng a muscle shirt.:B I was still pushing weights but my shoulder screwed up and I'm awaiting an MRI. I guess a screw driver with hydro( a Canadian thing) shut off. Mex, I`m going to check on the dielectric grease when I finish up here. I don`t have handles so that's out. Thanks everybody...maybe I`ll hire a young guy to pull them apart.:R Stay safe all. Bob
MEXICOWANDERER wrote:
I hope this did not ruin your day :)
While the dielectric grease may make it easier to get apart it actually hurts your electrical connection. Dielectric grease does not conduct electricity.
Fortunately this is a myth.
Prove me wrong :)
Go out to your rig yank the battery cables. Gob the grease on. Then put the cables back on, hit the starter. Again. Again. Twenty times. Then grab a brewski and wander around for the rest of the day scratching your head. A year later you'll remain wondering how and why.
Theory always takes a slapping when it faces practical experience.
Prove me wrong :)
frank-2 wrote:
l use a flat screwdriver to seperate them all the time
Prove me wrong :)
