Grit_dog
Aug 24, 2025Trailblazer
I assume you have a RV 50a config wired in. But sounds like you have it wired 240v not 2- 120 legs.
- mjm2198Aug 25, 2025Explorer II
Thank you for the response, that's correct, 50a breaker going to a 50a outlet box. Checking the outlet with a multimeter, each side is 120v on its own and 240v if I test them together. That's why im so lost.
- jkwilsonSep 06, 2025Explorer III
Measure while there is a load on the circuit. Hairdryer or similar. My bet is you’ll find one leg is too high and one too low, but still adding to 240V. Neutral problem.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
