time2roll
May 28, 2013Nomad
50a is really 12kW but the Yamaha should run two air conditioners.
I think you will want to use the 120/240v outlet with a proper adapter.
The new Magnum inverter will combine power with a generator to provide start surge or run the microwave etc as needed and then recharge battery when temporary high loads drop off.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
