vermilye
May 28, 2013Explorer II
kwinterb wrote:Just do the math - 45.8 amps @ 120V = 5496 watts, the entire output of the generator. Same at 240 - 22.9 amps @ 240 = 5496 watts. That is for a 240V load, or 22.9 amps per leg if you are feeding the RV's 120V loads.
I guess I'm confused, the 45.8 amps /52.5 amps @120V are the specs per Yamaha.
EF6300iSDE
But when you look at the generator, it has one typical 30 AMP female plug and two typical 20 AMP plugs.
If you look at the photo on the Gallery page of the linked site, they show a 4 pole 120/240 receptacle.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
