AllegroD
May 28, 2013Nomad
As others have said. You do not need 10k watts to run two AC. Depending on your setup, you can actually run both on 30 amp (3600W) service. You have to be careful though. If volts drop below 108, you get heat injuries to the ACs. Try to run anything else and you will probably trip CBs.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
