newsomer's avatar
newsomer
50 Amp Power Panel
I am replacing a power panel on our property. The old power panel only had 20 amp 120 volt recepticals. A friend who is a certifiex master electrician (now retired and out of state) inspected the panel and showed me it had 60 amp service. I have bought a panel box (Siemens TL137US) to install. The service is 4 ga three wire, two hot legs and a common. I know where to connect all three but where do I go with the ground bar in the box? Is it grounded to the panel box which is connected to the steel post in the ground? I found a grounding rod in the ground about eight feet from the post but I'm not sure if that's required if the system is grounded by the post.
