kerrlakeRoo
Jun 26, 2017Explorer
If you know that the wiring is 12-2 or 10-2 wire sized, and have checked the breaker, and verified that its a 20 amp breaker you should install a 20 amp outlet where you are going to plug the RV in. I know 15 vs 20 isnt a lot of increase, but if you are occasionally tripping a breaker , having the extra 5 amps can help, and ensuring that the outlet is a 20 amp outlet (one of the straight slots has been made a "T" shape) gives a slightly heavier connection in the outlet which can help with eliminating heating in the connection.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
