kerrlakeRoo
Jun 26, 2017Explorer
Chris Bryant wrote:
I agree that will be fine. I would say you can even use the A/C if the voltage stays good, making sure the outlet is good and tight.
If you know you have sufficient wire size, nothing else on the circuit, and yes a 8k and usually a 13.5k AC system will work. 15k is iffy.
But again you must have a good feed location and no extra draws on the circuit. Even the Charger/converter needs to be switched out until the AC is up and running.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
