2oldman
Aug 22, 2017Explorer II
jungleexplorer wrote:If this is a cheap enough inverter, there's a good chance it isn't capable of the startup surge. You can try other appliances like a toaster to see what it can do.
Since the unit is rated at only 515 watts and the inverter has a peak rating of 3000 watts, I find it hard to believe that the AC unit would have that steep of a start up curve..
You can read a sufficient voltage at the battery, but that doesn't mean it too cannot supply enough current. Hook it up to 4 6v batteries and some fatter cable and you'll have better chance at success.
If not, get a better inverter.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
