Gdetrailer
Aug 22, 2017Explorer III
jungleexplorer wrote:2oldman wrote:jungleexplorer wrote:Yes, but I think we understand you. I looked up that inverter, and it's pretty cheap. Yes, cheap is not good for this application, nor is ONE battery.
There is some misunderstanding.
This was the exact purpose of my test. To see if this inverter was up to snuff. I have done this with other inverters of the same rating with no problems. This inverter must be a piece of crapanese junk. I thought Tractor supply might have better products then Harbor Frieght. Guess not.
Buy junk at JUNK STORES for JUNK PRICES and expect BETTER JUNK?
Buy something like this..
Yeah, it can't be bought for JUNK prices but it WILL be the LAST inverter you will ever need to buy..
It is a Tripplite PV1250FC HERE for $290.
It is a INDUSTRIAL MSW 1250W inveter which IS specifically designed and built to deal with heavy INDUCTIVE loads like what a air conditioner or even a home fridge presents..
Here is some information on this inverter..
"Harness your vehicle's battery to efficiently power office equipment on the road or power tools at a work site.
Continuously supplies up to 1250 watts of 120V AC power to 2 AC outlets from any 12V battery or automotive DC source.
Frequency control locks AC output at 60Hz for operating stability of motor loads.
Includes a set of high current DC input terminals for simple, permanent installation.
Highly reliable large transformer design specializes in powering motors and other inductive loads with high-current startup needs. PowerVerter Plus Inverters accommodate "peak surge" demands by delivering more output power than their continuous rating.
Compare the "Continuous" and "Peak Surge" wattage ratings, and you'll find PowerVerter Plus Inverters supply up to double their output to easily handle equipment start up and motor cycling requirements.
A DoubleBoost feature provides up to 200% of the continuous output for up to 10 seconds, providing the extra power needed to cold start heavy-duty tools and equipment.
An OverPower feature delivers up to 150% of the continuous output for up to 1 hour. "
To sum it up, it can handle 1250W ALL DAY.
It can handle surges of 150% (1875W) for ONE HOUR!
It can handle 200% (2500W) of the rated wattage for TEN SECONDS!
None of the cheapy stuff you keep playing with will give TIME rating numbers.. Often cheap inverters will have the surge ratings of a couple of MICROSECONDS.. Which is why they are never listed.
To get a HF or a TS or any other cheapo inverter to fire your A/C unit you will need to DOUBLE the RUNNING WATTAGE..
Yeah, you will need one of those cheapo HF, TS or other import inverters that is rated around 3Kw-4KW in order to have enough snot to be able to support the start up LRA of the compressor.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
