DufusExplorerAug 13, 201650A male plug wiringI am replacing the male end of the plug. Does it matter which post red and black are on i.e. does it have to be the same on the male and female plug as long as ground and neutral are correct? thanks-Show More
MEXICOWANDERERExplorerAug 13, 2016Interchangeable L1 -L2IN THEORYDetermine which leg of your rig draws the highest wattage and feed that leg with the power feed L1 or L2 with the highest constant voltage.Freakin' nitpicking. But we nitpickers are helpless against it...
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 07, 2026
Related ContentAdding power outlets in slide with no wiringReplacing 30amp male plug7 pin plug amperage rating?Fleetwood Angler wiring30A male & female replacement plugs
